BTV 40k Liga 2020 - Armeelisten
Das Forum zur BTV 40k Liga
Sanul
Administrator
Re: BTV 40k Liga 2020 - Armeelisten
Post by Sanul »
+++ Necron 1500 (Warhammer 40,000 9th Edition) [82 PL, 10CP, 1,498pts] +++
Relics:
. The Veil of Darkness: Once per battle, at the end of any of your Movement phases, the bearer can use the Veil of Darkness. When they do, the bearer, and up to one friendly INFANTRY unit within 3" of the bearer, are removed from the battlefield. Then, set up the bearer (and the second unit you chose, if any) anywhere on the battlefield that is more than 9" from any enemy models (the second unit must be set up wholly within 6" of the bearer).
Warlord Trait
. Implacable Conqueror: You can re-roll failed charge rolls for friendly units whilst they are within 6" of your Warlord.
Dynasty Choice
. Translocation Beams: If a unit with this code Advances, add 6" to its Move characteristic for that Movement phase instead of rolling a dice (if the unit is being affected by the My Will Be Done or Wave of Command ability, add 7" to its Move characteristic instead). In addition, if a unit with this code Advances, its models can move across models and terrain as if they were not there.
C'Tan Powers
. Antimatter Meteor: Roll a D6. On a 2+ the closest visible enemy unit within 24" of the C'tan Shard suffers D3 mortal wounds. On a 6, it suffers D6 mortal wounds instead. If the C'tan Shard using this power is a Tesseract Vault, the unit suffers D6 mortal wounds on the roll of a 5+ instead.
. Cosmic Fire: Roll a D6 for each enemy unit within 9" of the C'tan Shard. Add 1 to the roll if the C'tan Shard using this power is a Tesseract Vault. On a 4+ the unit being rolled for suffers D3 mortal wounds.
++ Patrol Detachment -2CP (Necrons) [51 PL, 10CP, 888pts] ++
+ Configuration +
Battle Size [12CP]: 3. Strike Force (101-200 Total PL / 1001-2000 Points)
Detachment CP [-2CP]
Dynasty Choice
. Dynasty: Nephrekh: Dynastic Code: Translocation Beams
. . Dynastic Code: Translocation Beams
Gametype: Matched
+ HQ +
Overlord (Indomitus) [5 PL, 90pts]: Hyperphase Glaive, Tachyon Arrow
+ Troops +
Necron Warriors (Indomitus) [6 PL, 120pts]
. 10x Necron Warrior (Gauss Reaper): 10x Gauss Reaper
+ Elites +
C'tan Shard of the Nightbringer [9 PL, 165pts]: Gaze of Death, Power of the C'tan: Antimatter Meteor, Power of the C'tan: Cosmic Fire, Scythe of the Nightbringer
+ Fast Attack +
Canoptek Wraiths [16 PL, 225pts]
. 5x Canoptek Wraith (Particle Caster): 5x Particle Caster, 5x Vicious Claws
Tomb Blades [15 PL, 288pts]
. 9x Tomb Blade (Tesla Carbines): 2x Tesla Carbine
++ Patrol Detachment -2CP (Necrons) [31 PL, 610pts] ++
+ Configuration +
Detachment CP
Dynasty Choice
+ HQ +
Skorpekh Lord [7 PL, 130pts]: Artefact: The Veil of Darkness, Enmitic Annihilator, Flensing Claw, Hyperphase Harvester, Warlord, Warlord Trait (Codex 5): Implacable Conqueror
+ Troops +
+ Elites +
Skorpekh Destroyers [7 PL, 135pts]
. Plasmacyte: Monomolecular Proboscis
. Skorpekh Destroyer (Reap-Blade): Hyperphase Reap-Blade
. 2x Skorpekh Destroyer (Thresher): 2x Hyperphase Threshers
+ Fast Attack +
Canoptek Scarab Swarms (Indomitus) [2 PL, 45pts]
. 3x Scarab Swarms (Indomitus): 3x Feeder Mandibles (Indomitus)
Created with BattleScribe (https://battlescribe.net)
Warhammer 40k: Adepta Sororitas, Necron, Imperial Knights, Adeptus Custodes, Militarum Tempestus
Sullaner
Post by Sullaner »
++ Patrol Detachment 0CP (Necrons) [75 PL, 13CP, 1,495pts] ++
+ Configuration +
Detachment CP
Dynasty Choice
. Dynasty: Sautekh
+ HQ +
Imotekh the Stormlord [8 PL, 1CP, 150pts]: Warlord, Warlord Trait (Sautekh): Hyperlogical Strategist
Overlord (Indomitus) [5 PL, 90pts]: Artefact: The Veil of Darkness
+ Troops +
Immortals [8 PL, 180pts]: 10x Immortal, Tesla Carbine
Immortals [4 PL, 90pts]: Gauss Blaster, 5x Immortal
+ Elites +
Lychguard [14 PL, 300pts]: 10x Lychguard
. Hyperphase Sword and Dispersion Shield
Triarch Stalker [7 PL, 125pts]: Heat Ray
+ Fast Attack +
Destroyers [14 PL, 260pts]: Heavy Destroyer
. 4x Destroyer: 4x Gauss Cannon
+ Heavy Support +
Annihilation Barge [6 PL, 120pts]: Gauss Cannon
Doomsday Ark [9 PL, 180pts]
++ Total: [75 PL, 13CP, 1,495pts] ++
Dann ohne Dynastie Bonus !
AoS: Alle Untoten Legionen, Nighthaunt, Stormcast, Cities of Sigmar
40k: viele Necrons
Bolt Action: Deutschland
Klaivex
Post by Klaivex »
++ Battalion Detachment 0CP (Imperium - Grey Knights) [100 PL, 1,498pts] ++
+ Configuration +
Detachment CP
+ HQ +
Brother-Captain [9 PL, 118pts]: Edict Imperator, Fury of Deimos, Storm Bolter
. Nemesis Force Halberd
Grand Master Voldus [10 PL, 160pts]: Armoured Resilience, Empyrean Domination, Warp Shaping
Librarian [9 PL, 108pts]: 4: First to the Fray, Edict Imperator, Sanctic Shard, Storm Bolter, Warlord, Warp Shaping
. Nemesis Warding Stave
+ Troops +
Strike Squad [14 PL, 240pts]: Gate of Infinity
. 9x Grey Knight (Falchions): 18x Nemesis Falchion, 9x Storm Bolter
. Grey Knight Justicar: Storm bolter
. . Nemesis Falchions: 2x Nemesis Falchion
Strike Squad [14 PL, 240pts]: Vortex of Doom
Terminator Squad [13 PL, 190pts]: Hammerhand
. Grey Knight Terminator Justicar: Storm bolter
. . Nemesis Force Halberd
. 3x Terminator (Halberd): 3x Nemesis Force Halberd, 3x Storm Bolter
. Terminator (Warding Stave): Storm Bolter
+ Elites +
Apothecary [5 PL, 80pts]: Sanctuary
Paladin Squad [19 PL, 250pts]: Hammerhand
. 3x Paladin (Halberd): 3x Nemesis Force Halberd, 3x Storm Bolter
. Paladin (Warding Stave): Storm Bolter
. Paragon: Storm Bolter
+ Heavy Support +
Purgation Squad [7 PL, 112pts]: Astral Aim
. 4x Purgator (Psilencer): 4x Psilencer
. Purgator Justicar: Storm bolter
++ Total: [100 PL, 1,498pts] ++
El_Duderino
Post by El_Duderino »
++ Battalion Detachment -3CP (Chaos - Chaos Space Marines) [78 PL, 1,500pts] ++
+ Configuration +
Legion: World Eaters
Dark Disciples [1 PL, 10pts]: Mark of Khorne
. 2x Dark Disciple: 2x Close combat weapon
+ HQ +
Chaos Lord [7 PL, 106pts]: Bolt pistol, Chainaxe, Jump pack, Mark of Khorne, Warlord: Battle-Lust
Relic: Gorefather
Dark Apostle [4 PL, 80pts]: Benediction of Darkness, Mark of Khorne
+ Troops +
Khorne Berzerkers [5 PL, 104pts]: Icon of Wrath
. Berzerker Champion: Chainsword, Power sword
. 4x Chainsword and Chainaxe: 4x Chainaxe, 4x Chainsword, 4x Frag & Krak grenades
Khorne Berzerkers [5 PL, 109pts]: Icon of Wrath
. Berzerker Champion: Chainsword, Power fist
+ Elites +
Hellforged Contemptor Dreadnought [9 PL, 185pts]: Hellflamer, Hellforged deathclaw, Mark of Khorne, Twin lascannon
Hellforged Contemptor Dreadnought [9 PL, 175pts]: 2x Butcher cannon, Mark of Khorne
+ Fast Attack +
Chaos Spawn [2 PL, 46pts]: Mark of Khorne
. 2x Chaos Spawn: 2x Hideous mutations
Chaos Spawn [1 PL, 23pts]: Chaos Spawn, Mark of Khorne
+ Heavy Support +
Defiler [9 PL, 140pts]: Defiler scourge, Mark of Khorne, Reaper autocannon
+ Flyer +
Heldrake [8 PL, 150pts]: Baleflamer, Mark of Khorne
+ Dedicated Transport +
Chaos Rhino [4 PL, 81pts]: Combi-bolter, Combi-bolter, Mark of Khorne
Chaos Rhino [4 PL, 78pts]: Combi-bolter, Mark of Khorne
++ Total: [78 PL, 1,500pts] ++
Tablepop
Armeeliste Tablepop
Post by Tablepop »
9. Edition
Comand Points: 12
Quellen: Iron Hands Regeln, Codex Spacemarines
Armee: Iron Hands
Iron Hands Batailion
HQ
Kriegsherr: Master of the Forge (Techmarine 40),Combiplasma (10), Poweraxe (5), Servo Arm (0) 55 Punkte
Liutenant: Kettenschwert, Combiplasma, The Iron Stone (Relikt) 76 Punkte
Standard
6 Spacemarines Bolter Champion: Sturmbolter (3) , Kettenschwert 93 Punkte
6 Spacemarines Bolter Champion: Sturmbolter (3), Kettenschwert 93 Punkte
5 Spacemarines Bolter Champion: Sturmbolter (3), Kettenschwert 78 Punkte
Transport:
Razorback (80), Twin Assultcannon (40), 120 Punkte
Razorback (80), Twin Assultcannon (40) 120 Punkte
Unterstützung
Repulsor Executioner (250) (Machtpunkte 15) 371 Punkte
2 Frag storm Grenade Launchers (2x5)
Heavy Onslaught Gatling Cannon (30)
Heavy Laser Destroyer (40)
2 Storm bolters (2 x3)
Twin heavy bolter (30)
Twin Icarus heavy bolter (0)
Icarus Rocket Pod (5)
Auto Launchers (0)
Elite:
Redemptor DreadnoughtRedemptor Dreadnought 186 Punkte
2 x storm Bolter (6)
Onslaught Gatling cannon (20)
Redemptor Fist (0)
Heavy Onslought Gatling cannon (30)
Redemptor Fist (0)
Timpi
Vorstand
Post by Timpi »
++ Battalion Detachment 0CP (Imperium - Adeptus Astartes - White Scars) [69 PL, 1,500pts, 7CP] ++
+ Configuration +
**Chapter Selection**: White Scars
Detachment CP
+ Stratagems +
Relics of the Chapter [-1CP]: Number of extra Relics
+ HQ +
Captain on Bike [6 PL, 150pts, -3CP]: Master Rider, Storm shield, Stratagem: Chapter Master, Stratagem: Hero of the Chapter, Thunder hammer, Wrath of the Heavens
Chaplain [5 PL, 115pts, -1CP]: 4. Mantra of Strength, 5. Recitation of Focus, Jump Pack, Litany of Hate, Power fist, Stratagem: Master of Sanctity, Strike off the Head, Warlord, Wise Orator
Librarian [6 PL, 120pts]: 2) Lightning Call, 3) Ride the Winds, Force axe, Jump Pack, Plasma pistol, Tome of Malcador
+ Troops +
Assault Intercessor Squad [10 PL, 190pts]
. 9x Assault Intercessor: 9x Astartes Chainsword, 9x Frag & Krak grenades, 9x Heavy Bolt Pistol
. Assault Intercessor Sgt: Heavy Bolt Pistol
Intercessor Squad [10 PL, 215pts]: Bolt rifle
. 9x Intercessor: 9x Bolt pistol, 9x Frag & Krak grenades
. Intercessor Sergeant: Thunder hammer
+ Elites +
Invictor Tactical Warsuit [6 PL, 165pts]: Fragstorm Grenade Launcher, Heavy bolter, 2x Ironhail Heavy Stubber, Twin ironhail autocannon
Judiciar [4 PL, 85pts]
+ Fast Attack +
Outrider Squad [6 PL, 135pts]: Outrider Sgt
. 2x Outrider: 2x Astartes Chainsword, 2x Frag & Krak grenades, 2x Heavy Bolt Pistol, 2x Twin Bolt rifle
++ Total: [69 PL, 7CP, 1,500pts] ++
Henning
Post by Henning »
Lieber spät als nie :mrgreen:
++ Patrol Detachment -2CP (Aeldari - Drukhari) [32 PL, 610pts, 14CP] ++
+ Configuration +
Detachment Type: Prophets of Flesh
Raiding Force [4CP]
+ HQ +
Haemonculus [5 PL, 85pts]: Electrocorrosive whip, Hexrifle, The Helm of Spite
+ Troops +
Wracks [3 PL, 65pts]
. Acothyst: Haemonculus tools
. Wrack with special weapon (up to 1 for 5 models): Ossefactor
. 3x Wracks: 3x Haemonculus Tools
+ Heavy Support +
Talos [12 PL, 230pts]
. Talos: Macro-Scalpel, Macro-Scalpel
. . Two Heat lances: 2x Heat lance
++ Patrol Detachment 0CP (Aeldari - Drukhari) [41 PL, 775pts] ++
+ Configuration +
Detachment CP
Detachment Type
. *Custom Coven*: Dark Technomancers, Hungry for Flesh
+ HQ +
Drazhar [6 PL, 105pts]: Warlord
+ Troops +
+ Elites +
Incubi [4 PL, 80pts]
. 4x Incubi: 4x Klaive
. Klaivex: Klaive
+ Heavy Support +
Reaper [8 PL, 150pts]
Venom [4 PL, 75pts]: Splinter Cannon, Twin splinter rifle
++ Patrol Detachment -2CP (Aeldari - Drukhari) [7 PL, 115pts, -2CP] ++
+ Configuration +
Detachment Type: Kabal of the Black Heart
+ HQ +
Archon [4 PL, 65pts]: Huskblade, Splinter pistol
+ Troops +
Kabalite Warriors [3 PL, 50pts]
. 4x Kabalite Warrior: 4x Splinter Rifle
. Sybarite: Phantasm Grenade Launcher, Splinter Rifle
++ Total: [80 PL, 1,500pts, 3CP] ++
Paddy
Post by Paddy »
++ Battalion Detachment 0CP (Imperium - Astra Militarum) [83 PL, 10CP, 1,492pts] ++
Regimental Doctrine: Astra Millitarum, Jury-rigged Repairs, Spotter Details
+ Stratagems +
Tank Ace [-1CP]
+ Agents of the Imperium +
Inquisitor [4 PL, -1CP, 65pts]: 3) Dominate, 6) Castigation, Bolt pistol, Malleus - Psychic Mastery, Ordo Malleus, Power sword, Psyker, Stratagem: Inquisitorial Mandate, Tainted Blade
+ HQ +
Company Commander [2 PL, 37pts]: Boltgun, Chainsword, Warlord, WT: Grand Strategist
Tank Commander [12 PL, 200pts]: Battle Cannon, Hunter-Killer Missile, Lascannon, Slow and Purposeful
+ Troops +
Infantry Squad [3 PL, 50pts]
. 9x Guardsman: 9x Lasgun
. Sergeant: Laspistol
+ Elites +
Tech-Priest Enginseer [2 PL, 35pts]
+ Fast Attack +
Hellhounds [7 PL, 125pts]
. Hellhound: Heavy Flamer, Inferno Cannon, Track guards
+ Heavy Support +
Malcador Defender [17 PL, 330pts]: Demolisher cannon, x Heavy bolter, Heavy Stubber
+ Flyer +
Avenger Strike Fighter [12 PL, 235pts]: 2 Autocannon, 2x Lascannon
Vendetta Gunship [12 PL, 215pts]
. Vendetta: 3 Twin Lascannons
Andre S.
Post by Andre S. »
Chaos Knights [73 PL, 11CP, 1,435pts]
Battle Size: Strike Force 12 Cp
Super-Heavy Detachment (Chaos - Chaos Knights)
Dread Household [Custom Iconoclast Household]
Conquerors Without Mercy
Household Bonds
Abominable Constitution
Pinpoint Cruelty
Stratagems
Corrupted Heirlooms [-1CP]
Knight Despoiler [25 PL, 510pts]
Character (Corrupted Heirlooms)
Heavy stubber, Iconoclast Household, Stormspear Rocket Pod, 2x Thermal cannon, Titanic feet, Veil of Medrengard
War Dogs [9 PL, 160pts]
War Dog
Character (Traitoris Lance), Iconoclast Household, Meltagun, Thermal spear, Reaper chain-cleaver
Knight Rampager [21 PL, 415pts]
Eager for the Kill, Character (Traitoris Lance), Heavy stubber, Iconoclast Household, Reaper chainsword, The Gauntlet of Ascension, Titanic feet, Warlord
War Dogs [18 PL, 350pts]
War Dog
Heavy stubber, Iconoclast Household, Two War Dog autocannons
War Dog
[65 Reservepunkte]
40K: Night Lords, Chaos Knights, Daemons, Craftworlds
Ave Dominus Nox!
Klaivex
Post by Klaivex »
++ Battalion Detachment 0CP (Imperium - Adeptus Astartes - Blood Angels) [93 PL, 11CP, 1,499pts] ++
+ Configuration +
**CHAPTER**: Blood Angels
Detachment CP
+ Stratagems +
Armoury of Baal [-1CP]: 1 Additional Relic
+ HQ +
Astorath [6 PL, 110pts]: 4. Mantra of Strength, 6. Canticle of Hate, Invocation of Destruction
Librarian in Phobos Armour [5 PL, 100pts]: 2. Unleash Rage, 3. Shield of Sanguinius, Camo cloak, Icon of The Angel, Lord of Deceit
The Sanguinor [9 PL, 140pts]
+ Troops +
Incursor Squad [5 PL, 115pts]: Haywire Mine, Incursor Sergeant
. 4x Incursor: 4x Bolt pistol, 4x Frag & Krak grenades, 4x Occulus bolt carbine, 4x Paired Combat Blades, 4x Smoke Grenades
+ Elites +
Death Company [26 PL, 312pts]: Jump Pack
. Death Company Marine: Thunder hammer
. Death Company Marine: Bolt pistol, Chainsword
. . Bolt pistol and chainsword
Sanguinary Ancient [6 PL, 85pts]: 4. Heroic Bearing, Angelus boltgun, Death mask, Power fist, Standard of Sacrifice, Warlord
Sanguinary Guard [20 PL, 272pts]: Death mask
. Sanguinary Guard: Angelus boltgun, Power fist
. Sanguinary Guard: Angelus boltgun, Encarmine axe
+ Fast Attack +
++ Total: [93 PL, 11CP, 1,499pts] ++
Locked
